2006 Porsche C2S
This was a treat a 2006 Lapis Blue C2S. This was a full detail. (sorry no interior shots forgot to take them) The car was in good shape but as you will see there are swirls and imperfections. Interior was in great shape need a nice vacuum, leather cleaning/conditioning and wipe down. Products Used: Adam's Car Wash Adam's Clay Bar with Adam's Detail Spray as lube Adam's VRT Adam's Glass Cleaner Adam's Undercarriage Adam's Metal 1 and Metal 2 P21S Wheel Cleaner Gel P21S Autowash Menzerna 106FA Swissvax Cleaner Fluid Swissvax Concorso Einszett Leathercare Einszett Cockpit Einszett Detail Spray Tools: 3m Sun Gun Brinkman Xenon Portable Metabo 12-175 Tons of towels Procedure: Exterior: 1. Rinsed down the wheels (they were cool enough to touch) 2. Sprayed down the wheels with some P21S Wheel Cleaner 3. Sprayed down the wheel wells and tires with P21S Autowash 3. Brush and cleaned the wheels and tires with a Boar's Hair Brush 4. Rinsed down the wheels, tires, and wheel wells 5. Rinse the car down 6. Used the foamgun (Adam's Car Wash) to apply soap, let it sit and then 7. Used the Shmitt to wash the car, from top to hood to sides to rear. 8. Rinse car off throughly 9. Spritz some Adam's Detail Spray on the car and dried off the car. 10. Brought the car in and proceeded to clay the car using Adam's Clay Bar and Detail Spray 11. Used the Metabo with the Menzerna 106fa to polish out all the minor imperfections. (blue pad) a few passes per panel at 1500 rpm (Metabo rotary) 12. After each section was corrected I buffed off the excess polish with a MF Buffing Towel. 13. Applied Swissvax Cleaner Fluid and removed with MF Towel (removed after you apply in small sections, you don't want this to dray up) 14. Applied Swissvax Concorso by hand and let sit for about 10-13 minutes, buffed off to a nice wet and deep shine with a MF Towel 15. Cleaned up the windows with Adam's Glass Cleaner (interior/exterior) 16. Dressed the tires with Adam's VRT 17. Dressed wheel wells with Adam's Undercarriage Spray 18. Used Adam's Detail Spray to do a final wipe down on the wheels. 19. Used the 1Z Detail Spray for a final wipe down and inspected the car. 20. Polished up the tips with Adam's Metal 1 and Metal 2. Interior: Vacuumed the Trunk, Dressed the covers in the trunk area. Vacuumed the Interior Cleaned and conditioned the Leather treated with Einszett Leathercare Wiped down the interior (not the leather areas) with Einszett Cockpit Wiped down the door jambs with Adam's Detail Spray Cleaned Windows Now some pics: Before:
After wash:
Hood before:
Hood after wash:
Hood after:
Swissvax Concorso being applied!
Tips before:
Tips after:
Trunk after:
Now some pics: After inside:
After outside:
