BMW M3 - Full Detail - Detailer's Domain
This BMW M3 needed a full exterior, interior, and engine detail. The paint was in good shape, it only required one step with Power Finish. We finished it out with 1Z einszett Glanz. What was done - Exterior - Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down - Wheel wells were cleaned up - Pre Washed with W99 - Iron Cut - Wash down and rinsed - Door jambs were cleaned up - Clayed - Dried - Tires dressed - Masking - Paint Measurement -1 Step - Sonax Perfect Finish - Inspection with Fenix, 3m Sun Gun, Infratech, and natural sunlight - Last Step – Aquartz (3 coats) - Wheels pulled off and treated with Opti Coat 2 - Brake Calipers cleaned and treated with Opti Coat 2 - Wheel wells were cleaned and dressed - Rubber and Plastics Treated - Exterior windows and mirrors cleaned and sealed - Exhaust tips cleaned - Windows were clayed, cleaned, and sealed - Jambs steam cleaned Links to products used - 1Z einszett W99 Iron Cut Adam's All Purpose Cleaner Sonax Full Effect Wheel Cleaner Adam's Undercarriage Spray Uber Clay Bar Kit Menzerna Power Finish 1Z einszett Glanz Adam's Super VRT Adam's Metal Polish Adam's Glass Cleaner Interior 1Z einszett Cockpit 1Z einszett Leathercare Tools used Uber Wool Wash Mitt Uber No Name MF Towels Flex PE14-2-150 Uber Buffing Pads Defelsko Paint Meter Brinkmann Kranzle Pressure Washer Cam Spray Foam Canon 2 Grit Guard Buckets with Caddies Uber Firehose Nozzle Metro Air Force Blaster Before Interior After Before Prepping the car for polishing. Sonax Full Effect Wheel Cleaner Pre Soak Iron Cut Engine Before Engine After Clay Polishing with Menzerna Power Finish (50/50 shots) 1Z einszett Glanz used as a last step Final touches Pre Wow on Trim Pre Wow on the Cowl After shots
